Old 08-17-2015, 04:56 PM
rwairforce rwairforce is offline
Default Dedicated to plowing snow....
I would like to have a tractor that is always wearing snow removal equipment. I want one with a hydraulic controlled blade, lift and angle control.
I'm getting tired of my manual lift blade even though it has spring assist. After numerous lifts the old shoulder and back takes awhile to recover.
I've been using a Sears GTV/16 for 30 years. It's been fantastic but I want hyd capabilities. I really don't get enough snow for a blower and the blade system has worked well over the years.
What would be your suggestions? It doesn't have to be a Cub Cadet but I would prefer one. Thanks.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 08-17-2015, 05:00 PM
j4c11's Avatar
j4c11 j4c11 is offline
The 1872 and 2072 super garden tractors have front hydraulics and will take a 54" Haban blade. It has hydraulic lift and angle so it would fit your requirements, but they are not easy to find. I believe there are other super garden tractors that have the front hydraulics as well.
Old 08-17-2015, 05:31 PM
mudpatrol1's Avatar
mudpatrol1 mudpatrol1 is offline
this is the kind of question where you ask 10 people and get 10 answers. the machines i use in winter have either electric lift or hydraulic lift.of course after you decide then will you want a snow cab???? if so they can be either hard to find and or pricey so perhaps you would be better looking for a complete package
Old 08-17-2015, 06:25 PM
Get a Super with a power angle blade if you want a serious snow pusher. Just my 2 cents. For me I just stick my home made blade on my BX and Git Er Done. Takes all of 5 minutes to put this on the BX.
Now shut-up with the snow talk, I just got out of the pool.
Old 08-17-2015, 07:18 PM
mudpatrol1's Avatar
nice set up,seeing the snow during this heatwave makes me feel cooler.....
Old 08-17-2015, 07:37 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
1450, 1650, 782, 1812 all good machines and can have dual hydraulics tractors are easy to find, some already have hydraulic outlets on them.
The blades are easy to find and its easy to put a hydraulic cylinder on to angle the blade.
You will have a good snow machine for half the price of a super. Also the windbreaker cabs are easier to find and cheaper to.
If you did it right and wanted to do a little work, you could have a decent rig for abot 1200.00
Old 08-17-2015, 08:33 PM
GTKid GTKid is offline
You could also get a later cyclops if you wished, the 1882 and 2082 have the same power trains as the 1872 and 2072. If you want a more modern OHV engine there are the 2084/2284.
Only a 1282 with ~700 hrs(serial 729357)...
Just red and black and ain't goin back!
Old 08-17-2015, 09:44 PM
but the armstrong lift will keep you young.
Old 08-17-2015, 09:55 PM
Thanks for your responses.
Randy
John Deere 140 H3
Sears: GTV16
Old 08-18-2015, 06:00 PM
I use a 147 and manual lift/manual angle blade. Things I've noticed- even with the spring assist the blade gets heavy after an hour or so of snow removal. A hydraulic angle attachment would be great, but I can live without. The thing I really wish it had was more traction. Typical CC problems.... I'd either get a 782 with dual hydraulics (lift and angle) or 1450/1650 twin stick.
