Old 10-11-2015, 12:18 AM
Default Battery Cable
Guys, I want to replace the negative battery cable on the 982. It's seen better days. Should I replace it with a heavier gauge wire? And what gauge should it be? Thanks!
Old 10-11-2015, 05:59 AM
cubby102's Avatar
cubby102 cubby102 is offline
It definitely would not hurt to have a larger cable. I'm not sure what size is on there now. I'd probably just get the next size or two larger
Old 10-11-2015, 08:12 AM
twoton twoton is offline
Allen, while you're at it you might consider adding an additional ground wire, even if it's just 10 gauge from your negative terminal on your battery to the starter mounting bolt. If you're making up your own cable you can crimp the 10 gauge into the same lugg as the B- to chassis cable.
Old 10-11-2015, 10:22 AM
Thanks guys!
