Old 10-05-2016, 10:41 AM
SalGrey SalGrey is offline
Default Trans fluid and oil
What engine oil and transmission fluid do you recommend for a 1989 Hydro 1811?
What is 'low ash' engine oil? This is the type recommended in the owner's manual.
for above 32 deg, the lubrication table in the owner's manual says SAE 30; another section says 30W - are they the same?
Transmission fluid: owner's manual says Cub Cadet Hydraulic transmission fluid - meets IH B-6 specifications. Is there an equal substitute easier to obtain?
Thankyou!
Old 10-05-2016, 11:25 AM
Default 1811 engine oil and transmission fluid
Thank you!
Old 10-05-2016, 11:30 AM
Terry C's Avatar
Terry C Terry C is offline
This is what I use in all of mine:
Summer: SAE30 kohler brand
Winter. 10w 30 kohler brand
Trans: Hytran From IH dealer
Many use Hytran equivalent from farm stores
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 10-05-2016, 11:43 AM
I run Valvoline conventional in all my engines, for the rearend I use wix filters and hytrans from tsc. You will get a million different opinions on this subject but remember that as long as the fluids are full and changed regularly then it really doesn't matter what you use.
Old 10-05-2016, 02:57 PM
Thank you Tim and Terry for you advice on oil and transmission fluid! I am new to the world of garden tractors, especially old ones, so I have a steep learning curve ahead of me. Sal Grey
Old 10-05-2016, 06:43 PM
Sal
You started 2 threads with the same question, I merged them.
Old 10-05-2016, 10:17 PM
john hall's Avatar
I run Case-IH low ash oil in my 2072 (its never had anything else) and in my 982. The rest of the Cadets get the same Exxon 30W diesel oil that everything else around here gets(unless its a vehicle or ATV). I don't know how easy it is to get low ash oil from anywhere else, but I have heard folks swear their Kohler was less prone to burn oil if that is what they used in it. It's a little more expensive, but not much.
I use Hy-tran from Case IH in the hydro---unless I am out (normally I am). Then I use Hy-Gard from John Deere. Want to know a secret--the same company (Sunstrand) built the hydro pumps for IH and Deere.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
