Old 12-31-2015, 10:01 PM
dirtcowboy's Avatar
dirtcowboy dirtcowboy is offline
Default Brinly disk project
I finished my Brinly disk refurbish project yesterday. After replacing all hardware and 1 gang bolt (old bolt was bent from previous owner), stripping it down and putting it back together it's finally done. I went with the Case IH disk paint scheme on it and thought I'd share some pics.
Cub Cadets: 582, 682, mini 5288 and 5488
Case International 235 compact
Implements: Brinly cat 0 moldboard plow, Briy cat 0 disk, field cultivator, 1 row cultivator, wheelhorse fertilizer spreader, drop seeder, dump wagon, 44 inch deck, 50" deck, 60" haban deck, front snowblade, brinly cat 0 rear blade, homemade weight bracket, thatcher, harrow, Bush Hog pull type 50" flail mower, Haban 54" snowblade, 6 foot crumbler, straight shank
Living a dream one row at a time
Old 12-31-2015, 10:04 PM
looks good, nice job.
Old 12-31-2015, 10:23 PM
Terry C's Avatar
Terry C Terry C is offline
Cool disc!
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 12-31-2015, 10:24 PM
dirtcowboy's Avatar
Thank you
Old 12-31-2015, 11:46 PM
Very nice Jerry Which is going to be the primary pull tractor?:
Old 12-31-2015, 11:59 PM
bocephus1991's Avatar
Looks great! Number it a 196!
Brian
Old 01-01-2016, 12:14 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
That disk looks Very Sharp! You did a nice job on that. Looks straight up swell behind the dualed up 782 #jealous #sweeet
1- 1200 in pieces
1- 1864 in pieces
Old 01-01-2016, 12:44 AM
dirtcowboy's Avatar
The primary pull tractor for the disk will be my 982 but it's torn down to frame getting a paint job so for the pic to get it from garage to shed I hooked it up to my 782. Thanks for the great compliments
Old 01-01-2016, 12:47 AM
dirtcowboy's Avatar
Smile
Thank you, I have thought about numbering just haven't done it yet. I have a buddy building me another attachment for it and I'm working on getting 982 all redone to have by springtime.
Old 01-01-2016, 07:37 AM
john hall's Avatar
Very nice! Are you going to use it or show it?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
