Old 05-09-2010, 07:30 PM
sdowney sdowney is offline
Default wheel weights
I have a LTX 1046 lawn tractor and am having some trouble with the wheels spinning on a a couple hills on my property. I am considering wheel weights as a possible fix. Does anyone have any experience with wheel weights? Do they reduce the wheel spinning problem? Are they difficult to put on/take off? Would they stress the belt drive system? Thanks for any information...
Old 05-09-2010, 08:43 PM
Old 05-09-2010, 08:52 PM
johncub7172's Avatar
Why not go with 2-link tire chains and be done with it? It would seem to me that wheel weights are more weight to the tractor, and thus, making it work harder. I would use wheel weights and know what is gonna bust and be ready to keep it working. Try the chains, they should provide the most traction of the two.
Old 05-10-2010, 09:47 AM
wshytle wshytle is offline
I would try filling the tires with washer fluid. That worked for me using one of the green things a few years ago. If you use chains and spin you're going to have an ugly spot in the lawn. I think chains are mainly for ice and an occasional plow day, not for lawns.
Old 05-10-2010, 10:03 AM
Here's a thread that might help. http://www.onlycubcadets.net/forum/s...ead.php?t=3935
Old 05-10-2010, 10:15 AM
Opps! Forgot this one about loading your tires http://www.onlycubcadets.net/forum/s...ead.php?t=3215
Wheel weights are used all the time on belt and shaft driven tractors. I've used them on my Scott's mower for 13+ years with out any problems.
Old 05-12-2010, 12:19 AM
And you may not want to scoot across your black-top driveway with the chains.
Old 05-12-2010, 01:36 AM
murphycc
Guest
Posts: n/a
Just load the tires and you'll be fine.
Scott
Old 05-15-2010, 11:33 PM
ole 147 ole 147 is offline
I would get the tires loaded with windshield washer fluid at the dealer.
Much cheaper than wheel weights.
I use a 1045 Cub to mow. I have lots of hills in my yard, or should I say my yard is a hill and loading the tires worked for me.
The dealer were I purchased my cub loaded my tire for just the cost of the fluid since I bought the mower from him.
ole 147
Old 05-16-2010, 11:21 PM
If you really want to lower your center of gravity and gain hillability, fill the tires with washer fluid AND add wheel weights. I don't see where it would give any problems but I'm not experienced with that particular model. If needed, I would do that to my "lawn" tractor. The fluid filled only rears have done the job for several years now.
