Im refurbishing the 289 48" deck from my 3206 cub. Its solid other than this under piece which is all twisted up. It is in the middle behind the middle blade. Now, im assuming it has something to do with aerodynamics of grass clippings
![]() QUESTION: should I cut this chunck of metal out and call it a day or should I try to reshape it and weld it back in
Nroakes ![]() Cub Cadet 3206 Kubota AWD garden tractor GR2000 Allis chalmers B112 Bolens GT23 with P.S and hydro blade One big Green tractor Always looking for more projects! |
I would cut that section out. Buy a new piece of metal. Shape it to fit. Then weld it up (or have it welded).
Looks like it is part of the "deck baffle" and it does effect the cutting capability.
Thank you for the reply Roland.
Here is a pic from a different angle
Cutting new metal
Thanks for the help guys. I just couldnt wait for ANOTHER part to come in
![]() ![]() This should take care of it
I just got this 3206 last weekend and i'm tying to get it all fixed up asap
I'm not 100% sure if that will work or not. It should look like this.
That baffle helps to produce vacuum (suction) that stands the blade up...You may need to add more to the refurb there....
