I have a K321A in my 149 and it idles at half throttle if i pull the throttle down any more than half it shuts off. I am trying to make this tractor run and look good for the county fair and i dont really like the half throttle idle and plus it is verry annoying when you pull the throttle back quickly and end up pulling it down to far. Anyone have any suggestions on what to try im pretty sure its not the throttle linkage. Could it be the govrenor??
Cub Cadet 149 w/ sleeve hitch, rototiller, snowblade and deck, Cub Cadet 124 w/ sleeve hitch and deck Cub Cadet 1811 w/ deck and 18 big internationals 🇺🇸 🔧🐂 ![]() Brinley PP-100 plow Cyclone Rake |
First of all it doesn't sound like the idle screww is set correctly, it also sounds like to need to set the governor and adjust some linkage. If you got to the tech library you can download the manual that will walk you through making the adjustments.
