Old 11-16-2016, 06:21 PM
nutzboutoldies's Avatar
nutzboutoldies nutzboutoldies is offline
Default 1450 K321 front oil seal install depth.
I'm installing a new front oil seal in my 1450 K321 and am confused as to what the install depth should be. I have the manual but when looking at the cut away drawings I'm not sure which one to use. Of the four listed I believe it would be the Battery typical but the drawing for the breakerless typical resembles it closer. This engine uses points so it shouldn't the breakerless.
What depth do you guys use for the 1450 K321 engine?
Steve
1450
QA42A Thrower
44A Mower
Old 11-16-2016, 08:10 PM
If your putting in the seal in the plate you show, then it only goes in so far. Drive it in flush. The other seal needs installed past flush. 1/8" or so will be fine.
Old 11-16-2016, 10:18 PM
It only goes in so far? Is there a ridge that it goes up against? The manual makes me believe that maybe it is to be 1/2" deep? Maybe I'm over think this.
Steve
1450
QA42A Thrower
44A Mower
Old 11-16-2016, 10:50 PM
You might be able to put the crank in the plate and see where the old wear mark is on the crank, that would be an indication of depth.
Old 11-17-2016, 04:14 PM
Thanks, I was planning to do some measuring just to verify. The manual seems to have specific measurements it's just unclear which bearing plate I have.
Steve
1450
QA42A Thrower
44A Mower
Old 11-17-2016, 10:18 PM
Pretty clear to me which bearing plate you have... I can see the lip the seal rests on from my chair....
Your making this harder than it is. Seal depth is not critical. As long as the flywheel doesn't hit it, and you don't knock it clear into the block on the "front" (rear seal by specification), it's fine.
Old 11-17-2016, 11:38 PM
image upload no size limit
Old 11-18-2016, 07:22 PM
OldSkull's Avatar
OldSkull OldSkull is offline
There is no way he goes where Todd draw a line, The oil seal I got with my 1450 rebuilt kit is too small for that. The arrow show where mine is sitting (.5" depth... same place the old one was remove)
Gilles.
1963 100 (red)/in storage
Old 11-18-2016, 10:15 PM
Thanks for clearing this up Old Skull. The front seal for this engine is smaller than the rear seal and must go deeper than some of the other K321's I guess? You can see from these pictures the exact location and difference of size of the seal's. The rebuild gasket kit only had these two seals so I was pretty sure where they had to go it was just the depth I was concerned about. The pictures in my manual were a little confusing as I have points and and the images matching my bearing plate are for breakerless ignition.
Steve
1450
QA42A Thrower
44A Mower
Old 11-18-2016, 11:42 PM
I was figuring the outside/top of the seal. I NOTICED now, my line was a little to high. Sorry...
