Old 12-03-2016, 11:38 PM
Manfjourde's Avatar
Manfjourde Manfjourde is offline
Default This snow blade on my 102?
I'm new to this and the guy I got my 102 from said this will work on - can you verify?
Old 12-04-2016, 05:45 AM
That's the wrong subframe. Looks like it's for a QA wide frame. I would say look for another one unless that one is super cheap and then get the correct subframe. You need a narrow frame bolt on subframe
http://www.onlycubcadets.net/forum/s...ad.php?t=15335
Old 12-04-2016, 11:14 AM
Manfjourde's Avatar
Thank you much. The guy has another blade (not sure of sub frame) but the better blade is in the one pictured. Is it easy to swap blades if the other is the correct sub frame?
Old 12-04-2016, 11:18 AM
Yes, it is easy to do.
Old 12-07-2016, 12:13 AM
Manfjourde's Avatar
Quick attach won't work on my 102 bolt on, right?
Old 12-07-2016, 06:25 PM
Correct. Of course you can "make it work" with some ingenuity!
Old 12-07-2016, 08:40 PM
Just leave the quick attach pins on ( as in "don't cut them off" ) and bolt it on. That's what I did using my front blade on my former 122. I also used my QA-42 snow thrower on the 122 by bolting it on
Works perfectly.
