Does anyone know what the current rating is supposed to be on the circuit breaker used in a 1772 (925-3090)? I suspect mine may be on the way out and wanted to check it.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
It should be "inked" or stamped on this side of it. From the data I have, it states it is rated at 40A.
Thanks Roland. I think the PO did a power wash under the hood and soaked everything down. Even the glow plug timer had water damage as some of the PCB etches were corroded away.
Brown showed up at my door today with the replacement breaker. Cub Cadet wanted about 24 clams for it, I found an electrical supply house in WI that had the same rated breaker for $ 2.56 ! Anyway, replacing the breaker eliminated the chronic problem I had with the 1772 if it sits for mote than a week at a time. Going to crank the engine over, it would pull in the starter solenoid but not enough or with enough force to engage it with the ring gear or cause it to spin. You would just get a clunk. Like I said in a prev post, the PO power washed under the hood and I think some water got in there, and made for a dicey contact.
