Guys
I need the knurl diameter for a Cub wheel stud. Cub part number is 710-0852. I need to replace the studs on one of my Cyclops with something longer. Stock is 1.6" long and I need at least 2". Here is a pic showing the area I need measured. Thanks in advance.
I measured some I had replaced and it was .460
BTW you are supposed to answer questions, not ask them.
I don't use my Cub. I just work on it and look at it. So far it's holding up very well. |
Reason for this is that I got an 1863 carcass and a set of 10" wide JD wheels a few years ago from Leadslingingdaddy that I made into a 1641. The backspacing on the wheels caused the rim to hit the brakes. I put a 3/8" spacer on it and all was good. Fast forward to last week and I decided to switch mower decks from the 48 I had on it to a 46 and the tires hit the deck. I ended up putting a set of Cub wheels on that tractor but I need to correct the problem so that I can use the JD rims on my 1864. The studs are too short to use the JD wheels on the tractor that I want to put the JD wheels on, I can only get about 3 threads to catch. My guess is someone changed the studs on the 1863 because it looks like all the stuff I researched use the same stud. I can get longer studs, just needed to know what size to order and you had the answer. Off to Summit Racing we go.
Sam - NAPA has a wide selection of wheels studs available if Summit doesn't pan out.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
Plan B, just happened to look at my 149. I thought it had 23X8.5-12 tires on a 12X7 rim's it but it has 23X10.5-12 tires on a 12X8.5 rim's so what I'm going to do is replace the bolts on the 149 with 3" long studs then I can use my spacers and the JD wheels on the 149 and put the wheels from the 149 on the 1641. The bolts are a PITA anyway so 2 problems solved for cheap money. McMaster has the studs and lug nuts with very good prices.
Got the studs and nuts today from McMaster. Mission accomplished. Any of you guys need 10 wheel bolts for the older tractors? $10.00 shipped.
Pic of the studs on the 149.
Looking good, Sam!
