Old 04-30-2017, 09:20 PM
Ian Cub Cadet 125's Avatar
Ian Cub Cadet 125 Ian Cub Cadet 125 is offline
Default Hello
So ive read alot on here but am a new member but im 27 my name is Ian and im bringing back to life a 1968 cub cadet 125 that only ever blew snow its whole life I got from original owner so I found a mule drive and deck on craigslist new blades new oil pan. Anyways down to one final issue starting it has started fine but rather slow to fire it has a new spark plug and new battery but the starter will spin faster with it hooked up to the battery charger and fires immediately its not the battery I think im either getting too much resistance from my coil which reads around 3.0 or my starter needs to be rebuilt just wondering if you can help me find the solution faster?
Thanks
Old 05-01-2017, 01:08 AM
nra1ifer's Avatar
nra1ifer nra1ifer is offline
Hi, Ian. Welcome to the forum.
Clean all of your connections first. Could still be the battery.
nra1ifer
Cub Cadet 123, Wheel Horse C160, Craftsman PGT9000, Speedex 1631
Old 05-01-2017, 11:28 AM
Connections are all good I thought it might be my points so I looked and they were a little burnt so i cleaned them up and got my gap back to .2 hopefully it fixes the issue. Your opinion if the problem continues?
Old 05-01-2017, 12:37 PM
Green stripe wide frame's Avatar
Green stripe wide frame Green stripe wide frame is offline
You'll want them at .020
102 soon to be tiller machine
108 mower
73 plow machine
169 soon to be mower
122x2 now parts machines
Parts 129
149 parts
61 "O"
104 job to be determined
Old 05-01-2017, 01:51 PM
Terry C's Avatar
Terry C Terry C is offline
Try using the static timing method outlined in the tech section. Once I saw that I quit gapping points.
Put a new set of points in and try the static method.
As far as the starting better hooked to the charger, either your battery isn't big enough or your starter is pulling too many amps, or the connections aren't as good as you think. Sometimes corrosion is hidden inside the cable.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 05-01-2017, 07:24 PM
Thanks Terry maybe just repacing the wires for battery to starter generator wouldn't be a bad idea. And I did mean to type .02 gap my apologies I will update if any solution makes a superior noticeable difference.
Thanks for your replies
Old 05-01-2017, 07:25 PM
Also I will have to look into static timing I found a link however Im having a hard time seeing where the "S" mark will be seen does anyone have a better picture of this than this page:
http://www.mgonitzke.net/cubcadet/to...tic_timing.pdf
Old 05-01-2017, 07:39 PM
Originally Posted by Ian Cub Cadet 125 View Post
Also I will have to look into static timing if you have a link please share
Go to our "resources" tech library, tractors, 2nd page near the bottom.
Spend some time getting acquainted with our wealth of info
You will be amazed what you can learn here,
and yes we answer questions.
Old 05-01-2017, 07:43 PM
Trust us the "S" mark in there just darn hard to see sometimes.'
it should appear pretty close to the opening of the points, it helps to have a bright concentrated light.
once found, a white paint marker to highlight it helps.
Old 05-01-2017, 09:55 PM
Thanks George I got it figured out and it was actually right on and at full spread it was .020 now next issue I think it could be my coil now I had a battery tender on it and my key was on but my coil was super hot to the touch is this normal? Also my resistance on my coil with key off is 2.0 ohms does this tell you guys anything? So close to having this cub right back to 1968
