Trying to mount a 1a tiller on an 1811 and have everything BUT the plate that mounts on the rear end the tiller connects to. I think it's the plate that is part of the 3 pt lift, but not really sure what it's called. If someone could tell me what the correct terminology is, it might help me locate one easier and I can also post it in the wanted section.
The only way you can mount a 1A tiller to an 1811 is to make a custom adapter.
If you have a Cat O 3pt hitch, and the correct adapter, you can mount a 2B tiller. I made my own custom mount system, and it works wonderfully. |
I think I came across your custom plate while searching threads about this. If I recall right, I think you said it ended up looking almost like the plate that comes with a 3 pt? My thinking is it might beeasier to come up with that plate and modify it a little, rather than make the whole thing from scratch when I'm not even real sure it goes together in the first place. Complicated by the fact that the tractor is at my son's house and I can't just go out and look and cipher on it.
I'll do a little more digging - maybe find a pic somewhere that gives me a good idea on what it should look like. Then make something up from there. Thank you |
I am not sure you quite understand what I did.....
It works similar to the adapter for a 3pt. But looks totally different. Finding one is difficult already, and then you would need a 3pt to use it with. You better go get the tractor from your boy. I'm really good, but I still find it easier to work on something I can see. I never was good at telepathically building stuff. One of these days I'm going to build some more of these adapters and sell them. ![]() |
![]() Quote:
![]() Quote:
I guess you'd be able to mount other stuff too with the 3pt. But with a 1A, he still is going to have to buy the weld on parts for the tiller, or make his own if he puts it on a 3pt. The plate I made might have cost me $30. |
![]() Quote:
That's still more than $30.
![]() About 8 times more..... |
Sure is. But having never seen one, and only grainy pics to go by, I knew my limitations. Justified it to myself, all is good
![]() Probly would've been easier and less headache in the end to buy the model 400 (whichever one is self powered) that was about an hour away. But I didn't ![]() |
I think you're right J-Mech, I'm NOT sure! Hahaha. And although a 3 pt would be very nice to have, I'm not gonna complain, but yeah I'm not spending 7 times the amount I spent on the tractor to mount a tiller. I discovered last nite that if I substitute 782 for 1811 I get a whole lot more pics when I google. So I'm gonna take a gander at some of those pics until I can tell what I'm looking at/for, get the tractor in front of me and turn loose with the angle grinder and welder
