I saw this pic and it looks like I could just change the fan shroud and be able to add live hydraulics to a QL 1200!!??
![]() That sure looks like the pulley on the flywheel of the 1200 I got apart.
Are the gear drive quietlines like the older style gear drives, with the three pin driver and such? It may change the length of the driveshaft...but that could be cut and re-welded. Are you thinking of adding a NF hydro lift under the sheetmetal?
My 1200 got the exact same pulley behind the drive plate for the clutch.
The difference is Cub Cadet has an external fan shroud that partly covers the pulley. I guess the external shroud would reject grass better, ![]() BUT, I will be looking for an internal shroud before I put the 1200 back together!! |
Earlier Cub Cadets had the 'internal' screen, too. The external one seems to be more durable, so perhaps that had something to do with the change.
You could use the drive cup off a NF that has the pulley already on it that should work. You might run into some problems with the height of the frame rails if your going to bring it out the side like a NF hyraulic lift.
The clutch driver is bolted to the four holes shown on the Greene tractor. Just the screen is in the way, and when I last looked at it, the "bosses" that connect to the screen looked too high!! ![]() The flywheel might need a 4.5" grinder mod. !! I would try to put the pump under the hood. |
This is will be nice to see what you come up with, im planning on putting a powersteering pump on mine but on the pto end of the engine. Looking forward to your thread on it!
Original,100,123,129,1200,1250,168 in progress (3) 42inch plows, QA-42A,#1 tiller, 10inch brinly plow, Case Ingersoll 224, 1948 Farmall H, 1950 McCormick W-6, 1952 McCormick W-4. |
I haven't started rebuilding the engine yet!! |
Lets see some of the progress
