Old 06-19-2018, 07:38 AM
Mudrig150's Avatar
Mudrig150 Mudrig150 is offline
Default 1250 troubleshooting
I've noticed a few things about the 1250's supposed "misfire".
1. It still sounds like it has ignition. When the "Misfire" happens, it still pops like if the plug were still igniting the mixture.
2. It starts beautifully, most sources say your engine will hard start when it has a misfire.
3. It only happens after the engine has warmed up. It gets really bad at higher RPMs.
4. Happens when hitting bumps or when the engine is not under load.
Possible causes(?)
Dirty air filter? The air filter is filthy.
Exhaust valve not seating?
Bad coil or points? Seems like the coil is newer though.
Bad spark plug or wrong plug? I don't know, haven't checked it yet.
Cubs: 1986 CCC 1912 Kawasaki swap, 1984 MTD 782D, 1985 CCC 1210
Other tractors: 69 Deere 3020, 69 Deere 140 H2, 64-ish Burns B60
Old 06-19-2018, 08:13 AM
Sounds like a bad wire, or wiring connection.
I had a similar issue on my 1450, and it turned out to be a loose connection on the Condenser where it mounted to the engine.
