Old 08-26-2018, 10:23 PM
cnewell cnewell is offline
Default Tips for Adjusting Tie Rods on Cub 100
Hello,
I’m interested in any recommendations on how best to adjust the length of the tie rod distances for a Cub 100. I have the manual but the section covering this procedure isn’t very clear (at least not to me). Does anyone have a center to center length measurement that is standard for the rod that connects between the two spindles? I’d like to get an accurate setting to ensure proper toe-in. Also, same goes for the rod that connects to the steering column. If it matters, I just installed the Heim joints from McMaster Carr instead of the stock style.
Thanks!
Old 08-26-2018, 10:41 PM
There is not such thing as a "standard length" to adjust a tie rod to. You have to do each and every tractor individually.
Disconnect the drag link from the steering box to the front left spindle.
Set the toe in. I shoot for between 1/8" and 1/4".
Then, connect the drag link between the steering box and the front left spindle.
Set the length of it so that it steers the same in both directions.
Pretty easy.
Old 08-27-2018, 07:37 AM
Default Thank you!
Thanks J-Mech, I’ll give that a try. I appreciate the advice.
