Old 12-21-2018, 04:20 PM
jpw1400 jpw1400 is offline
Default Broken ACR tab
Short version: If ACR tab broke off my K321AQS, what are my options?
Just finished a complete rebuild. Cub Cadet 1450 was cranking over very difficultly, and would not start. After checking valve clearances, I took off the head and found that the compression release was not working. Pulled the cam cover, and could see that the ACR tab was bent down a little, and not even making contact with the tappet. Tried bending it up as gently as I could (it is one of the ones that did not have the hardened tab), but it just wouldn't stay up and give me enough clearance. Kept at it, but in the end it snapped.
So now there's no ACR tab, and motor can't crank over enough to start.
Do I:
(a) find a used camshaft somewhere, and give it a try?
(b) use a bigger battery/starter that can get her going without any ACR?
(c) give up.
The used camshaft option just has me a little nervous, as it might just put me in the same position I'm in now, if its ACR tab is not good.
Speaking of giving up... if anyone knows of a re-builder in the Rochester area of NY, I'm at the point where I'll pay for some help. I've been fighting with this for a while now.
Thanks,
Jim
Old 12-21-2018, 04:47 PM
john hall's Avatar
Never got one to bend, but all the ones I tried were hardened and SNAPPED. Bought a new camshaft. I don't know how much a new camshaft would be, but that's a lot of work to go through to install a used one that may be just as bad as what you had. My first step would be to price a new camshaft.
If anyone knows of someone rebuilding the ACR, please post it here.
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 12-21-2018, 05:51 PM
Garyoh5a Garyoh5a is offline
You’ll need to tear the engine down and install a new camshaft....sorry...I got same problem on my 1650 Cub K341
Old 12-21-2018, 11:25 PM
I appreciate the feedback. Looking around for a replacement... part number is KH-47-010-09. If anyone has one (with a good ACR tab!), please let me know and we can make a deal.
I really do appreciate the support on this forum. Hopefully we can get this old girl running again.
Old 12-22-2018, 06:11 AM
If you would like a good used Cam, place an Ad in the Want Ad Section.
Old 12-22-2018, 09:32 AM
Done. Thanks for the suggestion.
Tags
acr compression release
