Newbie question of the day.
What do I need to do to change the hydro fluid on my super? I believe it has a 1572/1772 rear end. The fenders and fuel tank are from a cyclops. I can't find a drain plug anywhere. I assume the rear cover will have to come off to drain the fluid? 3 point and rear PTO make it a little more challenging... P.S. - ignore the tin can next to the super ![]()
-Derek Cub Models: Original, 100 (x3), 1282, 1572, XT1 LT46 |
It has a drain plug in the front bottom next to the suction tube below the filter.
If it were me I first would be sure to get a new proper filter and hydro fluid. If after draining the tranny any milky colored fluid would prompt me to remove the rear cover and really clean out the cavity. I use a thin plastic tube down the fill tube which makes filling a bit easier. It mostly cures the burp back of fluid making a mess of tractor and person.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
Thank you Sam and Paul. I will call the local Cub dealer to see if they stock my filter and a couple gallons of HyTran. The manual states 8 qts. capacity. Does this sound right?
7-8 qts of fluid this is a list of approved filters, most can be found at your local auto parts store.
Cub Cadet 923-3014 NAPA 1410 Wix 51410 Fleetgard HF6096 Baldwin BT8486
Tags |
change, filter, fluid, hydro, super |
