Old 07-06-2010, 05:28 PM
apdevelopments apdevelopments is offline
Default How to free wheel on a cub cadet 1340
Hi.
I own a Cub Cadet 1340 with Hydrostatic.
How do I put the tractor in free wheel so I can push the tractor. I need to rebuild the engine but at the moment you need Arnold Schwarzenegger to push it. How do you make the tractor free wheel? is there a screw on the transmission or something?
Many thanks.
Old 07-06-2010, 10:32 PM
plummcrazy1864's Avatar
plummcrazy1864 plummcrazy1864 is offline
It may not free wheel, my 1864 does not. Tells me in the manual not to push it more then 10 feet could damage transmission. Check your manual it should tell you, good luck.
Old 07-07-2010, 01:14 AM
Old 07-07-2010, 06:02 AM
fuzzi4844 fuzzi4844 is offline
Some tractors have two valves under the seat (some under a small plate held by a bolt). On top of the valves is a small pin to press to free wheel. I have two 1811's. One has the pin style valves, the other no pins, and it free wheels without doing anything. Hope this helps.
Old 07-07-2010, 10:39 AM
midyearguru midyearguru is offline
Does the 1872 have a similar free-wheel device?
Old 07-07-2010, 01:46 PM
The 1872 has self-unloading check valves; all you have to do is roll the tractor.
The 1340 (and 1440, 1641, and a couple others) should have a release lever visible from the rear of the tractor on the rear frame cover plate.
Old 07-07-2010, 02:02 PM
cubs-n-bxrs's Avatar
I have a 1641 and the release lever is right on the tunnel cover.
Old 07-07-2010, 02:31 PM
I wonder what I thinking of then...I wonder if they changed that at some point? I could swear I've seen some with the release at the rear.
Old 07-07-2010, 02:40 PM
TEET's Avatar
TEET TEET is offline
I had a 2135 a few years back that had the release rod towards the upper edge of the hitch plate, you pulled it out and down to lock it into "neutral".
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 07-07-2010, 10:04 PM
Iowa Farmboy Iowa Farmboy is offline
[QUOTE=Matt G.;34233]The 1872 has self-unloading check valves; all you have to do is roll the tractor.
Are you sure on this as I have a 2072 that the fuel pump quit working and I could not push it at all. Unless it has to have more of a pull then I could do by hand. I do know that it had a sticker on the tunnel that said towing more then a few feet would result in damage to the trans.
