My son, has a 2072. He ran into some electrical issues last night. He called & I attempted to help.
The issue is the Fuses. In the 2072 Wiring Diagram, is shows two fuses. One fuse for the system, and one for the Lights. In looking at the 2072 Owners Manual, it only depicts one fuse (for the system). See Attachment, item #A. So, my question is, (a) where is the fuse for the lights located, or (b) is it just left of the Ignition Switch and CCC did not depict it correctly on their diagram (as indicated in blue). ![]()
I only see one fuse on this 2072 pic from the web
Then, where is the fuse for the Lights located ??
It's serial number dependant but this w/d from the svc. man. only shows one fuse.
Yet another one of Cub Cadets boo-boo's. Two different diagrams they publish and which one is correct. After the Son to get me a Serial Number now.
UPDATE.....
The 2072 has two different Wiring Diagrams. It is based on Serial Number Range. Oddly enough, the diagrams come from two different sources and neither source refers to the other. Diagram #1 - Serial Range 756,300 to 756,999 has two (10A) fuses on the Tractor Diagram #2 - Serial Range 757,000 to 799,999 has one (20A Slow Blow) fuse on the tractor. Diagram #1 comes from the Cub Cadet Wire Schematics document and no mention of Diagram #2. Diagram #2 comes from the Cub Cadet Service Manual (#772-3899) with no mention of Diagram #1 Yet, another Cub Cadet abnormality. Pull the trigger. ![]() ![]() ![]()
My 1914 has the second (blue) fuse. I believe it goes to the rear PTO.
