Old 03-23-2021, 12:19 PM
gkingbing gkingbing is offline
Default CC 1541 Reverse weak
The ole 1541 eventually got to the point where it barely moves in reverse although forward is fine. Could this be a hydraulic issue? The fluid and filter has been in there for at least 5 years. Thanks
Old 03-23-2021, 12:24 PM
The 1541 had two different Hydro Transmissions, depending on S/N range. They were: (a) Sundstrand, and (b) Hydro Gear.
What is the Chassis Serial Number of your tractor ?
Old 03-24-2021, 09:03 AM
Default 1541 model and sn
Model 141-651-100
s/n: 815597
mfg date A081G3
Old 03-24-2021, 09:16 AM
Thanks, you have a Sundstrand Hydro Transmission.
I would suggest that you reverse the roles of the Relief Valves and see if the problems follow the change.
Old 03-24-2021, 08:34 PM
Default Valves
Thanks for the suggestion. I will try to find out where they are located.
Old 03-24-2021, 08:40 PM
Under your seat.
