Old 04-08-2021, 11:29 AM
Daleag Daleag is offline
Default SGT brake backing plate worn?
I see SGT brake pads are NLA. I've seen posts suggest repadding them in the past, but not any that really document the process or where to find materials.
I also have another brake pad issue that a repadding isnt gonna fix. Mine has quite a lot of pad on them, but they barely work. When I went to adjust them I found that the caliper "arm" or lever or whatever you want to call it, had worn a notch into the backside of the pad's backing plate. The result being that I cant really adjust it tight enough regardless of amount of pad. I'm not sure what to do with it beyond break out the welder I havent unpacked yet, and I'm pretty sure that would destroy the pad material. Have any of yall encountered this yet?
Old 04-08-2021, 12:10 PM
What model of Tractor are you referring to ?
Old 04-08-2021, 12:17 PM
In this case a 1772, although my 1882 looks reeeeeeealy similar....
Old 04-08-2021, 12:25 PM
The 759-3185 Brake Pad was used on hundreds of models of Cub Cadet Tractors. Maybe a Internet Search for NOS or good used will bare some fruit.
Old 04-08-2021, 04:16 PM
Switch the pads, inside to outside.
Old 04-08-2021, 07:48 PM
**EPIC FACEPALM**
I didnt even check to see if the outers were similarly worn. I feel dumb now. Thanks!
Old 04-12-2021, 10:15 PM
FrankF3's Avatar
FrankF3 FrankF3 is offline
My Dad's 1872 had the same problem. I got a diestock out and threaded the brake rod a little more so I get the adjustment I needed.I had gotten some lining material from McMaster.com then used JB Weld to put the new lining on the backing plates. I don't remember the part number I used, I'll do some digging or if another member may know off the top of their head.
1989 - Cub Cadet 1772
38" Lawn Sweeper #196483
60" Haban Mowing Deck #196374
