I originally looked at this 1650 back at the beginning of the year. But I found a few others that I wanted to buy first. Then I saw it listed on Craigslist a few moths ago, but the ad was pulled after 2 days. They originally wanted $400.00, then $250.00. I ran across it again on Craigslist a few days ago, now for $150.00. It hasn't been run in about 4 years, but amazingly all the controls move freely. Take a look at the 1 picture & see why I definately could not pass on it again. Yes, it has a cat 0 hitch. The po said that they have owned it since the early '80's. The mower deck gave out early, so they mainly used it for gardening. They have a few attachments that I might go get later. They said that they had the dealer install the lift & the arm rests. The seat is shot, but I will put the arm rests on the new one. I need to put a rebuild kit in the carb. If it is like most of my recent finds, I hope to have it running in a few days. They listed it for $150.00 obo, I gave $125.00!!!
Great find and a better price! Nice cat hitch as well!
Looks like your making $$ On that one Great Find
Keep Us posted when its running
Cubbin on a rock |
Jarhead,
I would take that stack off or brace it before it cracks the block. |
jarhead
Nice buy on the 1650 |
Nice score on the 1650!
Great find Jarhead. Where did you find that at? I'm also in GA and look at CL at least 2 times a day. I have a bad case of yellow fever.
Well, after a few hours of tweaking the 1650 is up & running. I had to swap out the coil & carb. The first thing I do when I bring one home that has been sitting for a long period of time, is pull the spark plug & pour in some Marvel Mystery oil. Let it sit awhile & then turn it over by hand qiute a few times. These old K-series Kohlers are amazing. It seems that if you can turn it over by hand & not make any noise, you won't have much trouble firing them up. Everything works. I'm used to getting these that have been out in the elements for awhile & having the wiring harness all chewed up, & having to jump them off with a seperate battery & jumper cables. Not this one. The key switch works, the light switch works, as do the headlights. The directional controls work, with no creep. The hyd. lift works, but I will have to install a pin in the linkage to get the cat o to work. Oh. the stack was braced well by the po. It looks solid. Overall, for $125.00 tractor, I beleive this one will turn out to be a good one.
that was a nice find for 125! Even better that you got it up and running pretty quickly.
any plans to restore it or are you a fan of the rough and weathered look? |
Since you said you need to replace the seat, check this out. Fit perfect on my 1450, and you can't beat the price!
http://store.colemans.com/cart/repla...4868ca111b9423
Eric 1450 in progress.......... |
