Well I took everyones advice and got the rear axle reinforcements for the 2072. No instructions came with them but its pretty straight forward so I just took the weight off the rear end and bolted everything up. Refilled fluid and now I have a leak at the axle tubes. I installed the thin washers on the outside of the braces, should they be between the brace and the tube? Or am i forgetting/missing something else?
If I'm taking it apart again I want to do it right this time because refilling is annoying and time consuming. |
I think you need thread sealant on the bolts so it wont weep out.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
I just installed a set on a 1772, I put the washer under the head of the bolt and used little silicone sealant on the threads. No problems.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
Thanks guys I’ll pull them out and put some sealant on them, maybe I’ll work faster this time around lol
You can use a vacuum cleaner hooked up to the dipstick tube when you pull the bolts out. The suction will keep the oil from running out of the bolt holes. I use Permatex # 3 on the bolt threads. Clean the threads first with some brake clean.
I like that idea! I’ll let you know how it goes. Thanks
![]() Quote:
1872 with 50C deck 1862 with 50C deck 1641 with 48GT deck 364 snow blower IH Cub Original with deck GREEN 317 with integral sleeve hitch, front hydraulic |
Yep, I use an old vacuum pump for HVAC work to suspend the oil in the rear when replacing a leaking bolt. I use Permatex #2 and torque to 30 ft/lbs. Just make sure the area is clean so you don't suck any junk into the hole.
Will these braces interfere with the SGT cat 0 hitch? Looks like part of the brace mounts where the lower lift arms mount.
Adrian 2072 (789513) |
I have Diesel Doctors 1772 and it has a 3 point. I will look at it closer and shoot some pictures.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
