Old 05-26-2022, 02:41 PM
Swartzzz Swartzzz is offline
Default Cub Cadet 782 Woes.
This Cub Cadet 782 that had sat for 15-18 yrs, was brought back to life. Everything was going well. I was cutting like a champ my 1.75 acre lot. I put the machine in the shed when I was done, and everything was great. Fast forward 2 days, and the machine started to leak from the bowl of the carb. Great thing was that I had a freshly rebuilt carb, that I had in the cabinet.
Installed it, and now I have no fire. I was thinking that perhaps there was an adjustment not right, but I am at a loss.
I am going to check spark first and foremost.
Any tricks to check the carb? I was thinking that it may have a leak somewhere?
Old 05-26-2022, 04:27 PM
now I have no fire
Elaborate or better describe what you mean.
Old 05-26-2022, 05:37 PM
Here is what I did. I loosened the intake manifold and lifted it, to remove the carburator. Once I did that, and installed the other one, I saw an arch. Upon further investigation, there was a wire under the bowl of the carburator that was rubbed through. So, I used friction tape and taped it up. There is three wires with a connection near the firewall or dash on top of the engine. I re-installed the carburator and put everything back together, and I have no spark. I have a inline spark detection tool, and there is no light.
Could I have shorted out the condensor? Should I start there or order a coil as well. A Small arch wouldn't do anything else, would it? I checked both dash fuses, they look fine.
Let me know your thoughts.
Old 05-26-2022, 06:25 PM
Looks like this wire needs to be replaced with a new one.
Old 05-26-2022, 06:35 PM
I thought that I have it protected well. It was not cut through, just rubbed the insulation to the wire.
Could that short out the condenser?
Old 05-26-2022, 06:41 PM
You didn't say that prior.
Do you have a DVM or VOM meter ??
Old 05-26-2022, 06:57 PM
I am going to get one. I hope I can figure out how to use it.
What should I do to check it?
Old 05-26-2022, 07:09 PM
Sounds like a wire(s) is grounding out.
Old 05-26-2022, 07:32 PM
Any ideas where to start? Is it possible that the arc could have burned the condenser or coil?
Old 05-26-2022, 07:41 PM
To answer your question, no you didn't hurt the condenser.
follow the wiring diagram and check the wire you fried and determine where you loose the connection/ power.
Check the fuse & holder again. Don't guess,instead test
And you need not loosen the manifold to change carbs
Your original carb is prolly fine except it has something under the needle/ seat or check the float, it is a much better carb than a new off shore carb.
Don't panic and shotgun parts at it.
