Old 04-11-2023, 05:51 PM
zacsdad zacsdad is offline
Default Deck Belt info.
Hi Folks. Maybe someone here can help me? I have an old Cub Cadet model 1863 with a 46 inch deck. I think there is a mistake in the belt sizes for the two belts. Does anyone know the length of both belts? I have a BP-105 and a BP 100. The BP-105 is 108 inches in diameter, and the BP-100 is 103 inches in diameter. According to my Cub book, the Deck Blade belt is #754-3039, and the Tractor to Deck belt is #754-3048. The place that I bought the belts is telling me that the Deck Blade belt is the 103 inch belt. If I put that belt on the deck, The pulleys rub against each other and I had to disconnect the tension spring to get it on.? I had the 108 inch belt on the deck and it seems ok?? So, I guess my question is, which belt goes where? Thanks for any help.. Signed...CONFUSED
Old 04-11-2023, 06:15 PM
First, welcome to OCC.........
There are (3) production runs for the 1863. To narrow it down, what is the Chassis Serial Number of your tractor. The tag is located near the LH Brake Pedal. It will start with 8xxxxx.
Old 04-11-2023, 06:41 PM
Default chasis number
The chassis number is 867940
Old 04-11-2023, 07:23 PM
1863 (867xxx) with a GT46 (190-321-100) mower deck
* 954-3039 Deck Belt (Section A x 103")
* 954-3048 PTO Belt (Section B x 107.8")
Aftermarket:
* A-101 Deck Belt
* B-105 PTO Belt
Old 04-11-2023, 07:56 PM
Thank you for the information. I don't understand why the deck belt is too tight. I had to remove the tension spring to get the belt on. It is not possible to get the spring back on now. Two pulleys are rubbing together with the spring off?? Any ideas?
Old 04-11-2023, 08:22 PM
Is the deck and/or the Mule Drive installed correctly ???
Old 04-12-2023, 06:13 AM
The deck is not installed. I put the belt on with the deck off. The mule drive is fine.
Old 04-12-2023, 06:58 AM
How about some pictures depicting this problem ??
Old 04-13-2023, 10:52 AM
I took the belt off and it only measures 102 inches. So, I will return it and order an official Cub belt..
