Old 08-29-2010, 09:29 PM
wemo35 wemo35 is offline
Default howdy all from the buckeye state
previously inherited a 1986 cub 1512 deisel, runs great , but cant seem to figure out where the transmission is leaking from , guess i need to pull the fenders off & go from there , always a puddle underneath when i get done mowing , aside from needing brake pads runs & mows great
Old 08-29-2010, 09:32 PM
wemo35
Glad you joined us
When you get the fenders off let us know what you find.
Old 08-29-2010, 10:09 PM
camarokidz28's Avatar
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
Old 08-29-2010, 10:19 PM
ok not sure if im suppose to continue this thread or not , ok just pulled the fenders off , last summer my dad & i replaced both check valves on top ofthe transmission, they are dry , everything is wet from center down , am i going to have to pull the transmission to find out more , & if so is there an order in which everything comes off or where do i need to start
thanks for you help
chuck
Old 08-29-2010, 11:01 PM
Glad to have you!
Old 08-30-2010, 10:30 AM
Old 08-30-2010, 06:07 PM
Sminkey
Guest
Posts: n/a
Default Welcome aboard Chuck!!
thanks for you help
chuck
Hello Chuck, can't help you with this issue but I can recommend starting this thread in the General section here(IH Cub Cadet Tractors GT). You'll get alot more response there, good luck finding and fixing you're leak!!!
