Old 11-21-2022, 08:15 AM
Bburdette Bburdette is offline
Default New Cub Cadet XT1 L50 Not Cutting Even
Hello,
I am new to the forum hoping to get some answers on my brand new Cub Cadet XT1 LT50. I have had this mower for a few weeks now and can't get it to cut even. It leaves small streaks of higher grass. Everything has been checked and set to specs, but still nothing helps. Is the deck on the mower a floating deck or fixed? Does that anything to do with it? Could it be my lawn? It's not perfect level but I didn't have this problem when I had a Husqvarna . Any Ideas?
Thanks,
BB
Old 11-21-2022, 08:44 AM
Welcome to OCC..............
(A) Are the deck blades sharp ?? (B) Is the engine at full throttle when mowing??
Old 11-21-2022, 09:34 AM
Yes blades are sharp, and running at full speed. The mower is new. Thanks for the reply.
Old 11-21-2022, 09:44 AM
Properly adjusted both front to rear and side to side?
Blades on right side down and not upside down?
Belts adjusted properly?
This info should all be in your manual.
Old 11-21-2022, 09:46 AM
Yes, everything appears to be correct. Thanks
Old 11-21-2022, 02:39 PM
It's under warranty, have the dealer fix it.
Old 11-22-2022, 07:41 PM
Farmall450's Avatar
Ding Ding Ding
If everything is adjusted right I'd check that a blade or spindle isn't crooked. Tire pressures all correct?
Tags
cutting, lt50, mower deck, uneven
