I have a cc 1541 and a snow plow that was on my previous 1450 I thought they were all interchangeable, but the pins didn’t line up correctly, I had to grind half the pin bracket off and it still doesn’t seem quite right, and I can’t put on the wheel weights I have either the head of the bolt hits the disc brake
Your 1541 is a later model and use a different axle, yes you will have to grind off that area you mention. Are you using a carriage bolt?
