I hava recently bought an 1863 (i've had an 1864 for years) and it came with a snow blade. i'm wanting to mount the blade but i can't find any instructions and information on mounting it. It currently has a GT48" deck mounted on it. Do you have to remove the mule drive? Can anyone help me out with what all i need to do to get it mounted?
yes you need to remove the mule drive.
http://www.cubcadet.com/equipment/AR...90-376-100//1/
You can probably figure it out if you look over these parts breakdowns. Make sure you look at each attachment to figure out what you have. I tried MTDManuals but came up short. You can call them. Some times they come up with a manual and will email PDF to you. 1-800-269-6215
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 ![]() ![]() {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
Got it installed. It wasn't to bad at all. Now I need to look at it a little more to see if I can get the blade a little higher off the ground when I raise it. Right now it is only about 4” off the ground when it’s all the way up.
the bracket on the a frame the lift rod hooks to looks bent a little. straighten it make sure when you bolt it back on you hold the outer end of it forward . there's always a little movement on the bolts
Thanks. I plan on checking it all out tomorrow. I was going to today but it stormed all day. I also have a set of wheel weights, but not bolts for them. I need to measure them and see if I can find a set or just use all thread with nuts on both ends.
![]() Quote:
You can. I cut all thread and weld the nut to one end. Then I weld a nut to the rim. I only use two bolts per weight. I mean, come on.... even if they are 75lbs wheel weights, two bolts is plenty. You don't need 4. If you don't want to weld to the rim, no biggie. At least weld one nut to the all thread. Makes it easy like a bolt. |
I use culvert band bolts.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
![]() Quote:
![]() ------Way too loud for my old deaf ears. ![]() |
I usually just take a piece of all thread and nut both sides of it under the rim and then slide the weight onto the all thread. Makes a pretty easy install. No chains on the other hand, I struggle with.
