Ok, Silly question probably
but....I have a 1872 that was made by MTD from what I understand using IH parts, is that true? What does CCC stand for? Thanks |
Cub Cadet Corporation. 1872's were built in 1988 &1989 and the true IH parts were gone by then but, they are great tractors.
The only IH parts in an 1872 would be a bolt here and there. It is mostly IH-designed, however.
Found this from TractorData.com. Cool information! Looks like it also has all the cub cadet models.
http://www.tractordata.com/lawn-trac...-tractors.html "In the early 1960s, International Harvester entered the small tractor market with the Cub Cadet. The IH Cub Cadets were heavy-duty garden tractors many components borrowed from the larger Cub tractor, and built at the same factory in Louisville. In 1981, International's Lawn Products Group was sold to MTD in 1981 as the subsidiary Cub Cadet Corporation (CCC) and production moved to a new factory in Brownsville, Tennessee. While initially independent, Cub Cadets began to gain more common components with the other MTD brands and are now a fully integrated part of the MTD line. The Brownsville factory was closed in 2009." |
Where are the mowers made now? To me they stopped being Cubs about 1998 or so.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
To many ideas, not enough time..... Cub Cadet 147 2050041u340160 Cub cadet 129 main mower Cub Cadet 1811 Cub Cadet 1872 with 60" CCC deck. Many Mower Decks, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" and 12" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade. |
When MTD Closed the Brownsville Plant production was moved to Ohio at Willard and Valley City Ohio
I know this is an old thread, but the CCC Corp. headquarters were always right next door to the MTD headquarters, i.e., on the same campus. For about the first 9 years of CCC production, MTD more or less left it alone other than transmission changes. But by 1990, you started to see the MTD Influence with the change in hydraulic system components. When MTD did go to cheaper hydraulic system components
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force |
Cool stuff! Interesting to know. Thank you!
