Old 12-23-2010, 08:47 AM
JOHN SCHUTTE's Avatar
JOHN SCHUTTE JOHN SCHUTTE is offline
Question Reduction Cover Holes?
As I was getting ready to leave my shop last night, I noticed some "holes" in odd locations on the front reduction cover. 2 small ones about 1 1/2" to the left and right of the reduction drive shaft. Then I noticed 2 larger ones filled with grease/dirt about 2 1/2" below the smaller ones. I got a pick and got most of the crub out of the holes. It felt like the lower/larger ones had threads, so i grab a bolt (3/8-16) and it treaded in. These holes are pretty deep. It does not seem to interfere with the operation of the transmission, so what are they for? Does there need to be bolts in these lower holes? The upper small ones are not threaded, so what are they for?
Old 12-23-2010, 10:01 AM
Might help if we knew what model you are referencing...!!!
Old 12-23-2010, 10:04 AM
Sorry, the transmission came out of a 122.
Old 12-23-2010, 10:30 AM
Those are for the creeper. The creeper bolts to the bottom two holes, and there are some dowel pins that go in the upper two. Nothing goes there if you don't have a creeper.
Old 12-23-2010, 10:56 AM
Thanks Matt! Now it all makes sense.
