Old 01-29-2011, 01:27 PM
Flatbedford's Avatar
Default Where to buy Wheels?
I bought a newer Cub Cadet 15 cu.ft. cart this fall. The hub on one wheels has bent causing the hole to be too big foe the bearing. I bought a bearing with a larger O.D., but this is only a temporary fix. I figure that the hub hole will continue to deform with use. The wheel is a 4.00 X 8. The axle is 3/4". The tire size is 16x4.00-8. I have been searching all over the net and Ebay looking for a replacement wheel and haven't found much. Most I find are wheelbarrow wheels. I have attached a picture of the wheel.
I am also thinking of changing to a narrow front tire/wheel on my 125. I suppose I could use the wide tractor fronts on the cart if I found replacement wheels for the tractor.
Thanks,
Steve
Steve,
Former multiple 149 owner.
Old 01-29-2011, 02:26 PM
I think our fine Sponsors could help you out. Just click on the Boxes at the top of each page and I am certain you will find they are more than willing to help.
Old 01-31-2011, 03:31 PM
TSWolf's Avatar
TSWolf TSWolf is offline
Try your local Cub dealer, they will be able to order it.
Tyler
There are two types of people in this world: those who own cubs and those who wish they did.
I Own:
-1961 Cub Cadet Original
-1972 109
-many other non-cub cadets
Only 18, and already have multiple buildings full of equipment
Old 01-31-2011, 05:55 PM
I am trying to avoid my local Cub Dealer. They have so far proven to be either incompetent or very expensive, or both. Problem is that they were a JD dealer for 20+ years and switched to CC only 3 years ago or so. The parts guys just just don't know older Cub stuff and they have no older parts in stock.
Steve,
Old 02-01-2011, 08:46 AM
Mountain Heritage's Avatar
I suggest either the sponsors.....or worst case, find a nice set of wider tires/rims asembly at TSC or a farm dealer. You can normally pick the whole assembly up pretty cheap if your not in a rush. Around here they tend to go on sale a couple times a year - usually when they are not in high demand (like winter)?
Nice trailer by the way.
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 02-01-2011, 09:38 AM
Tractor Supply only has wheelbarrow wheels in 8" diameter. These are different. A member here might have something for me, just waiting for some snow to melt so he can get a good look at them.
Steve,
