Hi,
I started to rebuild carb on my 1450 today. Everything went fine until the last step of rebuild. When installing fuel bowl I noticed that someone had overtightened brass nut and caused threads to break and also cracked carb body around these threads. ![]() Tero |
No, you will need a #30
Then this someone also installed wrong carb. This is no #26 no wonder I cant get this engine to run at correct WOT rpm properly. Thanks for info
Tero |
Is walbro a decent carb? I saw this on Ebay:
http://cgi.ebay.com/New-KOHLER-CARBU...item1c1ac18b80 And I am wondering if it would be a good replacement. Tero |
![]() Quote:
![]() Quote:
Here's a good read on the walbro carbs. http://www.onlycubcadets.net/forum/s...ghlight=carter |
