Old 06-20-2009, 04:48 PM
fer100's Avatar
fer100 fer100 is offline
Default International 42" Blade with Spring Trip
Need some help guys after reading the directions for a hundred times I am ready to blow it all up . For the life of me I cann't get this thing hooked up to my CC122. the rear of the sub frame on each side has notches in it , does this set on the bar that goes across and holds the right and left foot rest together? if so where does the bar that's hanging down from the tractor with the 2 pins go. OR does the frame of the plow go to these 2 pins if so this is too wide of a sub frame for the 122! Then the front of the plow frame has the mounting holes but also 2 pins where does the 2 pins go? HELP PLEASE
Old 06-20-2009, 06:34 PM
fer100
The notch in the subframe should go right arount the rod holding the foot rest. It sounds like you have a wideframe subframe. Here are some pictures of my blade on my 149.
Hope this helps.
Old 06-20-2009, 06:37 PM
FER100:
How about some pictures of what you got...???
Diz....If I am not mistaken, the 122 is prior to the QA feature and has the "pin on" design.
Old 06-20-2009, 08:08 PM
fer100's Avatar
I cann't post any pictures my Daughter took the camera. But my front pins on the frame faces inward not outward like yours and my frame is straight not curved like yours in the back..My hydraulic unit is off the tractor so i took a pry bar and push the hydraulic cylinder back in turn my tractor peed on me so we came to the conclusion its drawn tonight. Ill leave it alone if it leaves me alone HA HA.
But tomorrow I'll try putting the back of the frame on the bar for the foot rests (some one put some large washers in there and i think if i move them around i might get it on). The bar that was in the way move when i used the crow bar. I'll have to see if the pins in the front get in the way of bolting it up. The frame does look like 2 pieces on the front sides were removed, but it looks like it will bolt up.,
Old 06-20-2009, 08:09 PM
fer100's Avatar
what is a pin on design????
Old 06-20-2009, 08:21 PM
FER100:
I don't know if this will help....but try this link.... BLADE
Old 06-20-2009, 08:25 PM
IH's first design for front mounted implements was a "pin on" or bolt on mounting. I believe starting in the 1x4/5 Series of Cubs, IH improved implement mounting with their QA (Quick Attach) concept. It made implement attachment soooo much easier.
THUS.....since you have a 122, the 42" blade would be a bolt on implement.
Old 06-20-2009, 08:34 PM
fer100's Avatar
I have the original operators manual but what you posted is a little bit different. I copied it and will compare. I did go back out and moved those washers around and got the back of the frame to set on the tractor but the steering linkage is in the way when i try to line the front up to the bolt holes either A bracket is missing or I have to find a mower mounting braket then attach the plow , (Illust 5 in that manual)
Old 06-20-2009, 08:37 PM
fer100's Avatar
Dpo you have a picture of this QA design. All the attachment I got with this tractor is surpose to go on this 122. But the more i get into it I finding things missing.
Old 06-20-2009, 08:58 PM
fer100's Avatar
Default Problem Solved ???
I do believe I found the problem. 2 parts are missing off the tractor, Cub Cadet part # 473922-R1 Brace Extensions (1961-1967) found this on parts Tree and ihccw has the parts going to order tonight.
