Old 05-14-2012, 11:03 AM
Leadslingingdaddy's Avatar
Default Alternative Tillers
I'm getting the Extreme 3pt hitch for my Super and I want to use a tiller but have no rear PTO... Has anyone ever used the self powered tillers you see on CL or EPAY?? 8-12hp...
Most of them are 36" so may have to add a tine or two....
Also was toying with the idea of making my own 3pt tiller out of a 'Donor" front tine platform...
Anyone every tackle this idea???
Randy
Old 05-14-2012, 01:16 PM
Shaner Shaner is offline
if you can, try to find a sears tiller. they used their own power source (usually a 4 to 8hp briggs and stratton) and used a 3pt hitch setup similar to one made for the super cub cadets. that may work for you.
Old 05-14-2012, 01:45 PM
Cub and brinly also had their own line of self powered tillers. Some cat0 some pull behind.
Old 05-14-2012, 04:37 PM
Yep I seen a Cub on EPAY and it was 32 or 36 wide....I can always put a bigger powerplant on it if I need to extend the tiles since the super is a bit wider...I think I need 42 inches to clear....
Will keep the eyes open..
Thanks
Randy
Old 05-14-2012, 06:13 PM
For less than the price of a tiller, you can keep the garden buried in composted mulch.
The earth worms will love you!!
Old 05-14-2012, 07:50 PM
You aint right! : -))
That means workin a shovel when I can RIDE!!!
BTW...Did your tractor sneeze and you didnt wipe it's nose??? Whats that green thing hanging fron it??? lol
Old 05-14-2012, 08:01 PM
hehehe!! Maybe some day I will remember to paint them!!
The 1872 could not pull the 1000 pound load into the garden without the front end weight.
The front end stayed in the air before the weight and bracket. More than once I had to steer it with the brakes!!
Kind of matches the seat!!
Old 05-14-2012, 08:13 PM
Oh the madness!!
Old 05-18-2012, 08:54 PM
TONYD TONYD is offline
High, my old 125 hydro came with a rear tiller that is powered by the mower clutch and a longer belt. You have to take the deck off and run the belt back to a gearbox that is mounted on the axle inspection cover and a belt go's to the tiller gearbox.
Old 05-19-2012, 08:11 AM
Tony,
I'm looking for my one for my Super...Had that setup on my 1650. Since rear PTO's are hard to come by for an 1872 I am putting a 3pt setup on and a Cat 0 tiller that is self powered.
Thanks
