KT-17s one of my intake valves to tappet has a clearance of .020, the the book indicates .003-.006. Could some comment on how this effects the operation of the valve over time. thanks Thomas
What engine are you talking about ?
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Kelly he said a KT17.
My guess is if you have that much clearance you have something wrong like the valve is not closing all the way.
![]() Quote:
Or a worn cam lobe...... Either way, I'd say time to pull the heads and have a look-see. |
Sam I guess reading the whole sentence is fundamental. LOL
I had to go back and re read it after your post. LOL
Don't feel bad Kelly, I do that all the time. Usually when the info is in the title of the post, but not in the body.
With .020 clearance it will be slightly noisy.
.020 is really not all that much as some of the old chevy solid lifter engines ran as much as .030 with no ill effects. The valves on those twins have no easy adjustment. To decrease clearance you have to seat the valve deeper into the head, or replace the valve. To increase the clearance, the valve stems need to be ground. Best to run it till it needs to come apart for rings/overhaul. |
![]() Quote:
sorry gents just the facts : took engine out had cylinders bored new pistons and rings10 over. pistons and rings installed at that time had shop grind valves and re-seat them . my opinion is shop took off to much on this valve or stem . this is what prompted me to ask this question.so I guess the answer is to replace this particular valve. also shop did not have all parts at the same time as I took responsibility for install . does this engine end up being the cranky motor or do I replace the valve and have it closer to the tolerance. just ranting thomas
Thread Tools | |
Display Modes | |
