What are your thoughts on replacing my 1250 for an 1811 with a 50 deck? My 1250 has lights and I converted to hydro lift. Also rebuilt the engine 4 years ago. Both in really nice shape. Can purchase the 1811 for a nice price.
I have a 1250 manual lift and a 782. I'd take the 782 over the 1250 any day. The only things the 1250 have over the 782 are better fuel economy and the engine is cheaper to rebuild.
A. 782 is very similar to a 181@. Chris |
No comparison. Can't go wrong with the 1811. Pinnacle of the GT's. Only thing that would have made it perfect would have been power steering. Diesel motor would be cool, but then it would be a 1512.
![]() Only difference between a 782 and an 1811 is the Mag engine. |
I have had three of the quiet lines, a 1450, and two 1650's.
And also an 1811 and a 782 (similar tractors). The choice was on which ones to keep, and I choose to keep the 1811 and sold the quietlines. I felt the 1811 is the best of the lot. Smooth running. Lots of little things sorted out (oil filter, fill plug for hydro, oil light, disc brakes (for a plan to add steering brakes), metal sheet panels). Having said that, some people prefer the older tractors. And the fact that they were made by IH. The twins on the 1811 are more expensive to rebuild if needed. Am sure there are other views/opinions, no absolute answer either way, just depends on what you like. (of course this forum is going to suggest you need both.... )
Keep BOTH....
I second that. If you can keep the 1250 for play and get the 1811 for mowing. You'll be surprised how many uses you find for the pair. I think I've had 4 going at once.
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 1872, 2072, 2-1864's, 1782, a few 42" front blades, 2 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
![]() Edit: OP Keep BOTH.... and buy a few others too!
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
Gerks, once you own one of the twin cylinder machines you will see what everyone is talking about and that one looks nice in the picture. The 1811 was one of the best built machines made. Not all 18XX's have the axle adjuster but the later ones do but that is also a simple fix if this one doesn't. As with all the aluminum rear machines, check the rear bolts.
If you get the machine you may want to add one of the cyclops rear frame covers to help with the bolts working loose like I did on the 1811 I once had if it doesn't have the cat 0 hitch. The SamMac brace would also be a great add also. DSC01939.jpg Good luck and go get it!
| Thread Tools | |
| Display Modes | |
