I found a cat 0 scoop tote on craigs list and reconditioned it, used a snowblower mount and fabricated the lift arm bracket and winch mount. Tell me what you guys think, do I need to reinforce the frame? Its attached to the front of the tractor with 2" angle and 1/2" gr8 bolts with a 3/8" backer plate and welded to the snowblower mount plate on the bottom. I tested it today and seems to work well, I plan on using my tiller for weight when Im scooping dirt. I am wondering about the frame rails and the strength of the frame at the frankenstien bolts. any thoughts?
I've been thinking about building something similar but using the hydraulic lift on the tractor and having a ram hooked to the front ports for the dump.
I really like the winch set up on the front, I bet that comes in handy. The front bucket is pretty cool also !
Cool looking unit! I wouldn't think it would be too much stress on the frame or Frankenstein bolts, but I'm sure others would have a better idea than me.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! ![]() |
That's pretty slick! I've daydreamed about doing something similar for fun, but I've got access to full size tractors and haven't figured out how to make it a 'need' yet.
Those front ends are pretty tough, but I think in an ideal world you'd have a support going from the bottom of the snowblower mounting plate back to the footrest supports like the front blade attachment system uses. That would make it much more durable in my opinion; you'd be able to use more speed and force loading the bucket before tearing the machine up. Just my two cents; have fun!
169 with tiller, 50C mower deck, Earthcavator, 42" front blade, Brinly tt100 toolbar, and QA42A snowblower, and now an Original! |
That's pretty neat!
Looks great, never saw one like that. Good luck.
I agree!
Thanks for the kind words and advice, I have been testing it some and the bucket works great - very useful! I did find a weak spot in my tractor though. The starter generator needed a rebuild as it wasnt charging very good and I ran my battery down using the winch. It had been getting weak over time and turning over very slow. Works great now though and I am sure it will cold start much easier - (spins fast)!
Thread Tools | |
Display Modes | |
