I read in a CC manual that a snow "thrower" is a single stage and a snow "blower" is a two stage. Is this correct? I'm shopping for one and want to use the correct terminology.
Thanks! Bob |
I've heard that also. Whatever you call it, you probably want a 2 stage blower if snow in Michigan is anything like we get in Minnesota. I had a 14 hp. Case garden tractor with a 36", single stage snow thrower. It never threw the snow very far. If the snow was anything but light, fluffy snow, it would plug up easily. I got a CC 1541 3 years ago, with a model 450, 45" 2 stage blower. It throws the snow well, and has never plugged up, even with really wet, sticky snow.
Mike |
bvanzalen:
You are correct... Snowthrower = Single Stage Snowblower = Two Stage
Thanks for tips. I was leaning the 2 stage direction. In southern Michigan, we only get 1-2 big snowfalls a year. Not really enough to justify a blower/thrower I'm thinking. I'll probably end up with a plow instead...I just like the idea of a big ole' blower/thrower up front! lol
I am North of you (Saginaw - Bay City Area) and I use both a plow and a snowthrower. As you know, it all depends on the type of snow and what you want to do with it.
Definitely. And the more attachments, the better...but I have a storage issue and a blower takes a whole bunch of space. Not one to leave stuff outside either. Sounds like I need a pole barn!
BTW, does CC make a snow plow and a dozer blade or are they one in the same?
Bob VanZalen 1974 Cub Cadet 169 |
IH made a front push blade for their Cubs....
![]() It came in either 42" or 54" widths. You just have to make sure on the Sub Frame for your application, if it goes on a NF or WF tractor. The NF versions had two types, Bolt On and the Quick Attach (QA). All WF sub frames were QA,
i think single stages almost work betting in wet heavy snow with the couple times ive used the 1650. i now have a 2 stage blower off a 782 i'm gunna make work on my 169
Nick. ![]() Cub cadets 100, 125, 86, 108, 109, 128, 129, 129, 149, 149, 169, 1450, 1650 and a handfull of parts tractors. #40 box blade, ih back blade, rear ih rock rake, #2 cart, windbreaker soft cabs, windbreaker hard cab, cozy cab, kwikway loader , wards corn planter, brinly plows, culitvator, rear blade, disc and the usual decks, snowblowers and 2 tillers |
I watched a guy one time with a single stage blower on gravel....what a mess! Mind you he didn't have any shoes that he could lower to lift the cutter bar off the gravel either. So am I going out on a limb that only a single stage blower should be used on pavement or cement drives? Every two stage blower I have seen had adjusting shoes so it worked fine on gravel drives.
Just throwing that out there. |
The IH built snowthrowers HAD skid shoes on them. If setup correctly, you should have no problem on gravel driveways. Ask me how I know....LOL
Thread Tools | |
Display Modes | |
