Old 04-08-2018, 06:04 PM
bcuster bcuster is offline
Default SGT 3PT Pics
Can someone who has a 2182 (or similar SGT) that has a 3PTH please upload a pic of the rear support plate? I'm used to the "beefier" upper link attachment on the regular 82 series 3PTH, and surprised of the simplified design on the SGT support plate. The pic of a SGT plate doesn't even look deep enough for the upper link to fit. What size diameter is the upper link pin?
Old 04-08-2018, 06:12 PM
For some unknown reason, the SGT upper link mount is smaller, and takes a non standard upper link. It uses a smaller pin. 5/8" IIRC, not 3/4".
I'd suggest cutting it off and changing the upper mount. A mount with 2 or 3 holes is better.
Old 04-08-2018, 06:54 PM
This 3PH went on my 2284,,,
I never had a top link connection failure, and I think I used the top link more than most SGT owners,,,
Old 04-08-2018, 07:31 PM
jbrewer's Avatar
jbrewer jbrewer is offline
The sticker on the seat is disorienting!
Great lift table, SGT and shop....
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 04-08-2018, 09:02 PM
Yes, the top link is very wimpy on an OEM hitch plate and you won't find one that doesn't need modified to fit.
Bill Ruegg's hitch is much better and will take a standard cat 0 top link.
As Jon said, grind off the existing one and space it out to accept the standard cat 0 top link. You may also be able to use a top link from a 3k hitch. IIRC they are made different and should fit.
Old 04-08-2018, 09:21 PM
MikeMasheris's Avatar
MikeMasheris MikeMasheris is offline
Top pin is 1/2'' instead of 5/8'' I put a flat 3/8 bar with a 1/2'' hole in it welded to a 1'' square tube with a 5/8 nut welded to the bottom and use the same lower link.
