Had a fun day working on my 2182. Got to use the Haban easy deck removal tool. Makes taking the early style Haban decks off a breeze. It’s a little pricy but it works awesome. Then I pulled the rear and pump out. I thought the cork gasket was the cause of my oil leak but now it looks like the seal on the trunnion shaft is shot. So not only do I have to replace the cracked front cover but I have to disassemble the pump to replace the seal. At this point I have decided to replace every seal and be done with it. I have a couple ideas on how to beef up the mounting for the fragile aluminum rear that is prone to breaking. Have to see how that goes. Got the rear cleaned up, on the bench and ready for surgery.
I would almost equate that lifting equipment to cheating, but only because I am envious.
I'm old, I have things that hurt that I didn’t know I had a few years ago, power tools make life easier.
Do those tractors have rear troubles as well. I thought with the beefed up axle tubes they may have also addressed the "loose rear" problem. I see u have the yellow rear cover plate, I heard that is big help to stop twisting of the frame. I have that same rear and axle tubes in one of my 2072's and it seems to stay tight. Keep us posted of your upgrades. Dave
Looking great there Sam, PLEASE take pics and do a write up as you go if you would please. Dad and I have the same rears as you and his is leaking a little and I will have to do the same at some point THANKS.
102-P Narrow tires no creeper--42inch deck and IH blade. 102-D Wide tires,creeper,headlights--42inch deck and CW36 snow thrower. 1997-2086 Super with 3 point hitch and all the bells and whistles. 1961-PTE-"O", needs lots of work. 2072-Repowered with a ch18, Woods tractor. 149 with my Dad. 44" deck and QA36A. #9-70 with weights and sleeve hitch. #10-149 with a 38inch deck. 2015 Kubota BX 2670. |
Sam great pics! Looks like another fun Sam project.
Dave
This girl has been run hard all her life. Pretty sure it was in a commercial lawn service application before the zero turns became the rage. It had been traded in for a big zero turn. One of the front mounts is broken. I have a cover to replace it. It will get some needed TLC and enjoy a life of leisure.Pic is the broken mount.
Great pics, Sam!
Sam bummer on the broken mount.
Can the casting piece be heli-arced back in place. I have one that looks just like that.
A friend has a Super he kept breaking bolts in the rear housing. He fabbed an aluminum plate that captured the two bolts in the housing at the rear and then bolted to the frame under the foot rests. Didn't work but he tried. |
| Thread Tools | |
| Display Modes | |
