I just got a cw-36 in good shape to mount on my 126. I looked up the shear pins since its serial # is above 111001 and found that IH-102677 is not available. Any thought where i can get some or a suitable substitute?
Don't think a coil pin is going to work here. The button head is held in by the metal clip.
do not know it this helps but for a shear pin on my woods mower deck i use a low grade bolt like a grade 2-3 . on my unit it takes a 1/2x3 bolt and i have been using these for 10 years now without a problem, and yes they will shear off if you push them beyond there limits. as a matter of fact if you have the rpms up and engage the pto to fast just the tourque from starting will take out the 1/2 inch bolt.
i just go to TSC and get there cheapie bolts for shear pins. |
![]() ![]() Isn't that a rivet? Looks like it to me - not really a shear bolt?? |
You know what it sure does look like a rivet. Wonder if its aluminum too?
I agree...looks like a steel rivet to me...I have a bunch just like that in my fastener bins.
Jeff (teet)
CCC 1211 71 127 ![]() 102 122 1962 Original |
http://ccmanuals.info/pdf/CW-36%20Sn...20Manual-2.pdf
by looking at the manuel it is a rivet you have there as a shear pin |
That's gotta be fun! Have to re-rivet things together in the middle of the night when your freez'n your *&$ off! Nice design, think the bolt would have been a little better???
You don't have to rivet it. It just pushes in.
Thread Tools | |
Display Modes | |
