Old 05-27-2011, 07:36 PM
Bad Brad's Avatar
Bad Brad Bad Brad is offline
Default saftey switch Cub 123
Where is the safety switch located on a 123.
Old 05-27-2011, 08:02 PM
Sounds like you might need to D/L the Chassis Service Manual for your Cub.
Here is the link: http://www.onlycubcadets.net/forum/s...ead.php?t=4641
Old 05-27-2011, 08:19 PM
Bad Brad's Avatar
I have this manual but I cant find it on the tractor, help.
Old 05-27-2011, 08:34 PM
It should be a brake safety switch. It will be located close to the brake pedal shaft that rotates when you apply the brakes. The shaft has an arm that is supposed to activate the switch. You will probably have to take the deck off and crawl up under it to find the switch.
Old 05-27-2011, 09:19 PM
It is on page 2-22,Look a little harder....there it is
Glad you found it!
Up to 534 and counting...
Old 05-27-2011, 09:45 PM
Bad Brad's Avatar
Thank You, I found it. Well, you found it
Old 05-31-2011, 12:22 AM
Bad Brad's Avatar
Well it was the started/generator. I got it replaced, well taken off my 100 and she started right up. I picked up a Cub Cadet 100 over the weekend to go along with the 123 and 125. I got the 100 because it came with a QA36 and a dirt/snow blade good deal for 300 dollars and a new carb and brand new harness for the 100 still in the ziploc bag with diagram.
Thanks for the help out there.
67 cub cadet 123 with Loader
http://www.onlycubcadets.net/forum/i...20Flag%201.gif
Old 05-31-2011, 12:30 AM
Glad you got it figured out, Brad!
Old 05-31-2011, 01:53 AM
Ditto! Now we need pics!
Old 05-31-2011, 03:43 PM
Bad Brad's Avatar
Pictures to follow. Thanks again.
