Old 05-22-2011, 09:54 PM
staylor1650's Avatar
staylor1650 staylor1650 is offline
Default balanced gears
i have been hearing alot of these balance gears going out and i was wondering if someone could shed some light on them
my question is what do they do and how do they go out
75 Cub Cadet 1650
64 Cub 100
not cub but its yellow 62 allis chalmers b-10
Old 05-22-2011, 10:32 PM
william1041200's Avatar
Its a heavy weight on its own shaft inside the engine. It is timed to the crank and the entire engine could do better without it. When it's bearings go, it's Kohler Armageddon!!
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
Old 05-22-2011, 11:12 PM
so can you remove them or do they have to be there curious
75 Cub Cadet 1650
64 Cub 100
Old 05-22-2011, 11:38 PM
you can and should remove them. Kohler discontinued them. We Should too.
snow/dirt plow
QA-36 snow thrower
Old 05-23-2011, 12:11 AM
CC1450's Avatar
CC1450 CC1450 is offline
here is a video where a guy has a K series apart so you can see the balance gears and what they look like.
http://www.youtube.com/watch?v=zAd5_hSYjlc
I'll be tossing mine in the scrap pile when I get to the reassembly stage of my rebuild.
-Mark
1978 1450
1976 1450
Old 05-23-2011, 11:36 PM
they are to even the balance of the engine from the torque of the combustion stroke. my mitsubishi 4 cly (4g6 motor ) has 2 a high speed and a low speed and idles smooth as glass also raises the red line but how well it works on CC ?
Old 05-24-2011, 06:41 AM
I removed the balance gears from both of mine. Heres a picture of the 16 h.p.
out of the 169. With the balance gears removed.
