Old 05-30-2011, 02:28 AM
Cub 61 Cub 61 is offline
Default Hydraulic lift mount?
I took off my hydraulic lift off of my 100 and was going to put it on my 70. Do you have to drill the holes in the frame? Because the frame doesn't have to holes.
Old 05-30-2011, 02:42 AM
Yes you have to drill the holes on the 70 and 100 frames. The 71,102,122 and 123 started the frames being drilled from the factory. All the info to drill your holes should be here.
http://www.onlycubcadets.net/forum/s...ead.php?t=7429
Old 05-30-2011, 12:16 PM
Thanks for the help. When I try to open it, it has an error.
Old 05-30-2011, 12:20 PM
DOH! It can be found here as well.
http://ccmanuals.info/pdf/
