Old 06-25-2011, 09:12 PM
krhoover krhoover is offline
Default Dual Wheels ?
Whats the story with some of the pics I see with the dual wheels? Was that a factory option, or is that a mod that you guys do. If so how is it done? What are the advantages of the setup?
Old 06-26-2011, 09:59 AM
dieseldan123's Avatar
Duels on the cubs were an option from IH as a means to better stability and floatation on golf course sand traps, to mowing on hills. They also provide better traction and reduce the foot print left on lawns to keep them in better shape. Duel wheel extensions can be found at xtrememotorworks.com and are the over all best bang for your buck in my opinion when it comes to the parts they offer. There are other ways to make your duels but ill leave that for some of the other guys to chime in. Hope this helps!
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 06-26-2011, 12:56 PM
camarokidz28's Avatar
This is what my spacers look like to put duels on my cubs , or even 3 tires on each side
I take a piece of 20 gage steel that is 2 inches wide and 33 and 3/8 th long and use a metal roller to make it round . Then weld it together . and use reddy rod that is threded ,and cut to lenth I need .
Denny
Original Member # 389
Saw It
Wanted It
Had A Fit
Got It
Old 07-01-2011, 06:09 PM
jeffscub's Avatar
jeffscub jeffscub is offline
most certainly no wider than 2 inches. i made mine 3 and they are HUGE. looks pretty neat though. jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
