Old 07-23-2011, 01:20 PM
ROWDY72 ROWDY72 is offline
Default Newbie 129 Owner
HELLO Recently bought a Cub Cadet 129 at a local auction Been doing some tune up work to it ,Oil, Air , Htdro Fluid & filter , cleaned & degreased everything ,ect. Haveing some troubles keeping it running it seems to boog down wene in motion full speed or near it . to the point were it stalls or nearly stalls. If I put direction selector to N the RPM's build back up . Is this a Hydrostst problem or a Ignition / Run problem I put a new silanoid & cond the points look like there brand new unsure of Volt Reg. Looks older ?? ( on flat level ground or up hill ) Thanks for input in advance. I need to get me a good service manual as well any sugestions ?? I will add some pics this weekend Thanks Again !!!!
Old 07-23-2011, 01:54 PM
Also seems to mainly boog down wene PTO is engaged I adjusted the PTO belts in front did'nt seem to help ?? I'm going to try to add a couple pics as well.
Old 07-23-2011, 05:37 PM
CC1450's Avatar
CC1450 CC1450 is offline
welcome to OCC forums!
I would guess your running issues are carb/ fuel delivery related. If you have not done so already, pick up a carb rebuild kit for around 10 bucks or so, and go through it.
-Mark
1978 1450
1976 1450
Old 07-23-2011, 06:35 PM
Nice looking 129!
Old 07-23-2011, 06:40 PM
Here is the link for the Kohler service manual:
http://www.onlycubcadets.net/forum/s...ead.php?t=4646
And the Service manual for your 129:
http://ccmanuals.info/pdf/1x8-9%20&%...e%20Manual.pdf
Old 07-23-2011, 06:59 PM
Sweet looking 129!
Old 07-23-2011, 09:30 PM
I installed an inline fuel filter on it , It did'nt have one, that should'nt effect anything should it ? Were would I get a carb rebuild kit on ebay or ?? I bought the tractor an extra wider deck & a snow plow at auction for $ 400.00 I think I did good ??? I actually need it I'v got about 2 acres to maintain & my 12 yr old Craftsman riding mower is dieing , I'm actually glad it's sooo Hot out it is giving me time to get the Cub running perfectly before I need to mow again .
Old 07-23-2011, 09:44 PM
Our sponsors banners at the top of the page is a good place to start for a rebuild kit. Also your local Cub Cadet dealer should be able to get you what you need.
Old 07-23-2011, 10:01 PM
johncub7172's Avatar
Hellow! Welcome to Only Cub Cadets.net! I would clean out the fuel tank, replace any rubber fuel line. Sounds like it may be flooding a little? Nice tractor A Cub Cadet is for KEEPS! Will last you a life time! Can you afford to keep replacing CHEEP machines? Nice to have you with us!
