Old 07-31-2011, 01:45 PM
jpackard56's Avatar
jpackard56 jpackard56 is offline
Default Decided to work on #73 no fuel issue...
PO said this tractor ran when it was parked
Can you say when "Hector was a pup?"
The photos say it all
The positive note is that since this is so blocked there was virtually NO fuel in the carb to turn into varnish over the last umpteen years since it was "parked"
Simple rebuild on the carb should do it. This will be a working tractor (well maybe) Should I mess with this fuel bowl arrangement or change to inline filter?
Old 07-31-2011, 02:02 PM
I would replace it with another one. One of my local small engine repair shops stock a replacement Oregon sediment bowl that is all metal even the adjusting nut at the bottom of the bowl. The plastic nuts on the bottom break after a very years so make sure you get a all metal one.
Old 07-31-2011, 05:58 PM
scleve scleve is offline
I agree, I've had better luck with sediment bowls.
Old 07-31-2011, 06:13 PM
gcbailey's Avatar
gcbailey gcbailey is offline
for what it's worth, love the rainbows!
Gary
Old 07-31-2011, 06:37 PM
TEET's Avatar
TEET TEET is offline
I agree with Gary...nothing like a rainbow to make your sediment bowl "pop" !
I've had sediment bowls that look like yours in the past, and cleaned them up to be usable again. Another option is to go to Napa and pick up a steel, lawn and garden petcock of the appropriate thread size, and splice in a modern gravity feed fuel filter in-line.
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 07-31-2011, 09:59 PM
jpackard56's Avatar
Yep, the kids were "using" the camera between my dis-assembly steps...I was too messy to take the shots, sooo, rainbows appeared!! Guess, they had some fun with dear "old" dad
