Are the floor board plates/ traction pads ,interchangeable between the 82's and say the Quite lines? I guess the easy question is will the steel tread plates for a Quite line or other model fit the 82's correctly ?
I need to put something on my newly painted fenders and cant find anything. I don't really want the replacement rubber kind. Any help, or suggestions ? Thanks Joe
Sold everything but one. 1211-snow pusher, cab ,54 inch plow, loaded tires (all 4) Gilson wheel weights, X-trac fronts- soon to have power steering and dual hydraulics |
I would stick to the rubber ones,On the metal ones it is just another place for rust to form...
I was thinking Aluminum, but everybody lists them as fitting the quite lines or wide frames.
Well I know a set from a 1x6 1x7 will line up with the holes,but you will have one extra hole,and without a fastner in it,it will prolly rattle.You would also have to make a cut out on the right side for the rockshaft.
I guess I will just have to pick up a piece of diamond plate and make my own.
They are not a different size, but you can use them on a 82 series by drilling one extra hole for the back bolt. Did that on my 682...
They don't trap stuff and cause rust any worse than the rubber ones. |
Matt,
You know when I laid them on the 782 they look a whole lot better than the rubber ones.Some would not drill extra holes,"wanna keep it correct",but I see nothing wrong in doing it for this purpose.
Exactly. I had them and I used them. They weren't doing me any good sitting in a box.
I was going to make some out of aluminum diamond plate, but that may be asking for dis-similar metal corrosion where they contact the fender pan. The salt in the winter will also destroy them. |
Thanks guys, I might see if there is a cheep set on ebay.
I bet Mike has a set or two he's not gonna use!! You might want to check with him. He's right down the street from ya.
2013 cub cadet GTX 2100 w/IH weights 1984 cub cadet 1282 w/#2 cart, plow, IH weights 1970 IH cub cadet 73 w/fenders Haban 402d sickle bar 1966 IH cub cadet 102x2 1966 IH cub cadet 71 pull start w/Fenders IH sweeper, Brinly Gard N Cart 1965 IH cub cadet 100 w/Fenders hydro lift Brinly Gard N Cart, 3 point sleeve hitch Brinly plow sleeve hitch blade #1 cart 1965 IH cub cadet 70 w/fenders and snow plow 1961 IH Cub Cadet Original #3646 w/fenders 3 point, IH rear blade, non trip snow plow |
